Tempest Weather Meter for Agriculture
Measure The Weather
In The Middle Of Your Field
Tempest WEATHERmeter For Agriculture
MSRP US $99.95
WFANO-02c-AG
Use the WeatherFlow-Tempest WEATHERmeter and your smartphone to capture accurate location-specific weather conditions and report the data instantly to farm managers. Make sure weather conditions comply with regulations before spraying.
- Wind speed (avg, gust, apparent, true)
- spray drift monitoring
- irrigation management
- .csv data export
- add tank mix & spray notes
- Free mobile app
Compatible Devices
WEATHERmeter for Agriculture uses Bluetooth Smart technology (also known as Bluetooth LE) to connect to all Apple iPhones 4S or newer & iPads Generation 3 or newer operating on iOS 6.0 or newer. They also work with Bluetooth Smart Ready Android phones & tablets with operating system 4.3 (Jelly Bean) or newer.
Additional Specifications
| Measurement | Range | Accuracy | Notes |
| wind speed | .5-125mph | ± 0.5% | calibrated by University of Florida Aerospace Engineering |
| wind direction | 0-360° | depends on phone/device | |
| humidity | 0-95% | ± 3% up to 85% | |
| atmospheric pressure | 8.9 to 32.5 inHg | ± 0.03 inHg, 1mbar | |
| temperature | -10 to 140 °F | ± 0.7 °F | |
| Bluetooth range | up to 100 ft | ||
| Battery | CR 2450 |
- Wind Speed
- Wind Direction
- Wind Speed(Avg)
- Wind Speed (Gust)
- Temperature (Dry Bulb Temperature)
- Pressure
- Humidity
- Apparent Speed
- Apparent Angle
- Dew Point
- Wet Bulb Temperature
- Wind Chill
- Heat Index
- Feels Like
- Air Density
- Delta-T
- Headwind/Tailwind
- Crosswind
