Handheld Wind & Weather Meters
Highly accurate miniature weather devices used with your smartphone to measure wind, temperature, humidity and pressure readings. You can record data in a variety of compatible apps including the free Wind & Weather Meter app and share reports instantly via email, SMS, Twitter, Instagram, and more.
WEATHERmeter
WEATHERmeters are miniature weather stations you use with your smartphone via bluetooth to collect real-time wind, temperature, humidity and pressure readings. Readings are recorded and displayed directly in the ‘Wind & Weather Meter’ app. The free app is available on App Store and Google Play.
WEATHERmeter
Precision Shooting
WEATHERmeter for Precision Shooting was designed for ballistics calculator apps and allows shooters to capture a complete on-site atmospheric profile including wind, temperature, pressure, relative humidity and density altitude. It integrates seamlessly with the BallisticsARC and Shooter (Ballistic Calculator) mobile apps to provide long range shooters with a complete atmospheric profile.
WEATHERmeter
Agriculture
Use the WeatherFlow WEATHERmeter Agriculture and your smartphone to capture accurate location-specific weather conditions and report the data instantly to farm managers. Make sure weather conditions comply with regulations before spraying.
WINDmeter
Wind Meter is a pocket-sized anemometer that captures highly accurate wind measurements. It connects to your iOS or Android device via bluetooth. Use the free ‘Wind Meter’ app or other compatible apps to record and share wind reports.
