Tempest WEATHERmeter
Take and Share Weather Reports Anywhere
MSRP US $89.95
WFANO-02e
The Weatherflow WEATHERmeter is a highly accurate miniature weather device used with your smartphone to measure wind, temperature, humidity and pressure readings. You can record data in a variety of compatible apps including the free Wind & Weather Meter app and share reports instantly via email, SMS, Twitter, Instagram, and more.
WEATHERmeter connects wirelessly to your smartphone up to 100 feet away. From sailors to farmers, now anyone can capture and share accurate weather data with the WEATHERmeter.
- Wind speed (avg, gust, apparent, true)
- Wind direction (magnetic, true)
- Crosswind, headwind, tailwind
- Temperature & relative humidity
- Pressure & dew point
- Heat index, wind chill, and more
- Wireless connection up to 100 ft away
- Held in hand or attached to any 1/4-20 camera mount
Compatible Devices
WEATHERmeter uses Bluetooth Smart technology (also known as Bluetooth LE) to connect to all Apple iPhones 4S or newer & iPads Generation 3 or newer operating on iOS 6.0 or newer. They also work with Bluetooth Smart Ready Android phones & tablets with operating system 4.3 (Jelly Bean) or newer.
Additional Specifications
| Measurement | Range | Accuracy | Notes |
| wind speed | .5-125mph | ± 0.5% | calibrated by University of Florida Aerospace Engineering |
| wind direction | 0-360° | depends on phone/device | |
| humidity | 0-95% | ± 3% up to 85% | |
| atmospheric pressure | 8.9 to 32.5 inHg | ± 0.03 inHg, 1mbar | |
| temperature | -10 to 140 °F | ± 0.7 °F | |
| Bluetooth range | up to 100 ft | ||
| Battery | CR 2450 |
- Wind Speed
- Wind Direction
- Wind Speed(Avg)
- Wind Speed (Gust)
- Temperature (Dry Bulb Temperature)
- Pressure
- Humidity
- Apparent Speed
- Apparent Angle
- Dew Point
- Wet Bulb Temperature
- Wind Chill
- Heat Index
- Feels Like
- Air Density
- Delta-T
- Headwind/Tailwind
- Crosswind
